Setting custom tab stops in style sheet
terrence wood
Post by terrence wood »
How do I set custom tab stops for in the style sheet?
cchapin
Post by cchapin »
Pretty much the same way you would set them in Draft View or Page View. You'll need to show the ruler if it isn't showing (Edit > Ruler).
Because of the style-list column, the full margin-to-margin ruler might not fit in the window. You can double-click a ruler droplet and set its position that way.
--Craig
hatchmo
Post by hatchmo »
What is a ruler droplet?
Al Hatch
Ruler markers/droplets are any of the little icons that mark special distances on the ruler. Eg: a tab stop has a little black arrow for its marker.
midwinter
Post by midwinter »
You guys need a blog series of "hey! what's that thing called?!" :wink:
