LinkBack problem
GeoffRoynon
LinkBack problem
Post by GeoffRoynon »
I have NWE 2.5 and OmniGraffle 4.0 and decided to play with LinkBack. I created a drawing in OG and copied and pasted it into a document in NWE. This works well. When I double-click the drawing in NWE it starts OG and I can change the drawing and the changes appear in NWE. This is as it should be.
The problem comes in if you forget to save the updated NWE document, your changes will be lost. NWE does not show a dot in the red bubble at the top left of the document to show that the document has been changed, and the Save icon in my toolbar is greyed-out.
If a drawing in a NWE document is updated, surely the document has been changed and you should be reminded when you close the document that it has been updated?
Geoff
rmark
Post by rmark »
Geoff,
Good point. We'll take care of it.
Write On!
Mark Hurvitz
Nisus Software Inc.
