Way to sort a list?
NisusUser
Way to sort a list?
Post by NisusUser »
Hi, everybody.
Seems like there was a macro or some way to sort a list. Is that so?
I want to sort a selection in this file (I'd select the first part and sort it first, then the last few at the end of the 2nd column).
Thanks!
Sample_file_sort.rtf
(41.44 KiB) Downloaded 1080 times
Re: Way to sort a list?
As long as the items in your list are all single paragraphs you can just use the Sort command.
NisusUser
Post by NisusUser »
Thank you, Philip! I thought it was in there somewhere, but when I looked down the lists of menu items, I didn't see sort, so I decided it must have been a macro. Now I see that it is here: Edit > Transform Paragraphs > Sort …
I appreciate it!
