Move table rows
johseb
Move table rows
Post by johseb »
I downloaded a couple of macros to move table rows up/down (written by @phspaelti and shared in the thread https://nisus.com/forum/viewtopic.php?f ... own#p30721).
The "Move down" macro works perfectly but the "Move up" macro doesn't.
I had a look to the macros but the issue is not apparent to me; it could be a problem with the macro itself or with my system.
Philip, any chance you can have a look to the macros? :wink:
Thanks
Move Table Rows Up.nwm
(7.08 KiB) Downloaded 849 times
Move Table Rows Down.nwm
(7.22 KiB) Downloaded 870 times
Re: Move table rows
This failure is not Philip's fault. It looks like the issue is due to the way Nisus Writer incorrectly interprets the selection created by the macro:
$insertPoint = TextSelection.new $cell.text, Range.new(0,0)
That generated selection should always be a text insertion point, no matter what. However, if the targeted table cell is empty the text selection is promoted to a full cell selection– a table selection. That distinction doesn't normally matter, but with such a selection in place the macro's paste operation inserts the row(s) at the wrong location, one row too far down, and thus there's no change in content.
There's a few ways we might work around this problem. The macro could instead generate a selection that's one row earlier, like so:
If $insertRow.location > 0
	$selectRowRange = Range.new $insertRow.location - 1, 1
	$insertPoint = TableSelection.new $sel.table, $selectRowRange
End
But as the "If" statement's location check may reveal, this only works when you don't need to move rows to the very top of the table.
A complete workaround could instead insert a placeholder character into the empty cell, so the proper text selection is always generated by the macro. Once the macro finishes moving the table rows, the temporary placeholder can be excised. I'll attach an amended macro that uses this strategy. I'll also file a bug report that we should fix this macro selection behavior.
Thanks!
Move Table Rows Up.nwm.zip
(2.99 KiB) Downloaded 858 times
johseb
Re: Move table rows
Post by johseb »
Thank you Martin, the macro now works like a charm (and thanks to Philip for writing the two original macros).
Re: Move table rows
Thank you, Martin.
I'm glad you were able to fix that. The problem and its solution would not have been obvious to me.
