Format as Web Link
Format as Web Link
A new feature in 2.5, that I cannot find in the documentation or in the release notes, is HTML formatting.
If I copy a link from a Web page in Safari and paste it into a Nisus Writer 2.5 document, it appears as a proper link. In other words, it's colored and underlined -- but the "http://www....etc." is invisible. The cursor even changes into a hand when you point at the link.
This does not happen when you drag-and-drop the link, nor does it happen in Version 2.1.3.
How do I format my own links this way from within Nisus Writer?
Al Hatch
HeatherKay
HeatherKay
Preference option?
I have to agree that auto-recognition of links can be really annoying, but in some circumstances, it can actually be what you're after.
You're probably going to do this anyway, but FWIW, my vote would be to have this as a preference option, so that weirdos (!) that do like the Word behaviour, will have that option.
The default should probably be as previously described; have this option OFF, and require the user to manually select 'Make web link' or some such formatting command.
Please please please do NOT make the default behavior to auto-discover links. Word makes me want to throw my computer out the window every. single. time. it. does. this. It is the most utterly counter-intuitive behavior in the world and could only have been the brainchild of a company that didn't think twice about asking users to click a button labeled "start" to turn their computers off.
If you do add a preference for how to auto-discover links, I suggest you bury it somewhere odd in the menus and maybe write the description of what it does in some language no one speaks anymore. Latin, perhaps.
OK. I feel better now.
It could be interesting to have 'link auto detection' as a style property, so that you can set this as the default behaviour, but still allow exceptions, such as retrospectively adding this property; I'm thinking of situations where you want to produce a PDF version of a paper, for instance, that includes active 'clickable' URL references.
