numbered paragraph formatting
SolidLight
Post by SolidLight »
Every time I try this, it is impossible. I try and try and try, and I can't get it to do anything consistently. My Nisus Writer Guide is for an earlier version. I have 3.5.7. with Mac OS Sierra 10.12.6. If I could just get something that was consistent I'd be glad to be done with this.
Re: numbered paragraph formatting
I'm sorry you're having trouble. You mentioned "numbered paragraph formatting" but perhaps you could be more specific? What are you trying to do exactly?
Generally speaking you control numbered lists by assigning a list style to one or more paragraphs. For example, select a few paragraphs of text and apply the "Number List" style. You can then control the appearance of all list items using that "Number List" list style via our stylesheet. That way you can consistently enforce a number format (eg: 1-2-3 vs a-b-c) and other settings.
