Writer saves only as Text Edit with Mac OS 10.12.3
SolidLight
Post by SolidLight »
Hi - I don't seem to have the option to save a NISUS Express doc as that. It always becomes Text Edit, thereby I lose all the features of Express, and I lose my headers and footers.
Re: Writer saves only as Text Edit with Mac OS 10.12.3
Hello. I generally use NWPro not Express, but I think they are the same in this respect.
The file format of NW is ".rtf" which by default opens in TextEdit on a Mac. Did you check the "Info" of your saved file in the Finder?
If your file doesn't "belong" to Nisus Writer, change it, and then click on "Change All". From then on all '.rtf' files should open in Nisus Writer Express.
