How do I work with Kodak PhotoCD images in Nisus Writer?
Moderator: faq-editor
Post by martin » 2004-09-08 15:31:54
Kodak PhotoCD images are stored in Kodak YCC format. There are also lo-res PICT versions on the PCD. Importing the PICT version should be no problem. They come in 5 different sizes, contained in 5 different folders on the disk. If you want to use the YCC image files for improved color, you'll have to pull them into Photoshop first. [retrieved from the <A HREF="http://www.nisus.com/Support/MailingList.php">Nisus list</A> February 4, 1997. Thanks to Joe Milligan.]
