Nisus Writer Express 3.5.6 released
Locked
This update improves compatibility with macOS 10.12 Sierra.
This update is free for all license holders of Nisus Writer Express version 3.
Requires Mac OS X 10.8.5 or later.
Get the Update:
You may download the new version from our website.
If you purchased through Apple's Mac App Store (MAS), the update is also available there.
If you purchased from Nisus Software directly, unfortunately you cannot update automatically inside the app.
You must download and install this update manually– sorry for the inconvenience.
Changes:
• Fixed problems with macOS 10.12 Sierra:
- Crashes when using the document version browser (using the menu File > Revert To > Browse All Versions).
- The use of Soft Return characters can trigger incorrect spacing, indentation, and drawing.
- A warning about invalid bookmark data can appear after relaunching, if the user quit with Untitled documents open.
• Fixed: using the system's Markup feature on an image would incorrectly remove that image.
• Fixed: some issues with LinkBack. Restored LinkBack functionality for OmniGraffle (version 7.1 or later required).
Locked
