InfoClick 1.2.2 released
Locked
Post by martin » 2016-09-06 15:46:44
This update improves stability and fixes bugs.
Requires: Mac OS X 10.7 or later.
This update is free for all existing users of InfoClick.
Get the Update:
You may download the new version from our website.
If you purchased from Nisus Software directly, you can update automatically inside the app, via the menu InfoClick > Check For Updates.
If you purchased through Apple's Mac App Store, the update is available there now.
Highlighted Changes
• Fixed: emails with certain kinds of malformed MIME envelope data could trigger crashes.
• Fixed: pressing the Tab key (or Shift + Tab keys) should navigate between all areas of the search window.
• Fixed: adjusting the index update period in the preferences would incorrectly change the zoom.
For a full list of changes, please see the release notes.
Locked
