Questions about Tables (2.0.7)
NisusUser
Post by NisusUser »
Is there a way to select table columns? In Word for Windows I could click at the top of a column and select the entire column and then drag left or right to select more. Is there anything similar in NWP? I checked the PDF manual for "column selection" and "select columns" and came up with nothing. Thanks.
NisusUser
Re: Questions about Tables (2.0.7)
Post by NisusUser »
I found it! Shift-Cmd-A.
NisusUser
Post by NisusUser »
For a multi-page table, is there a way to assign headers to a table so those headers will repeat at the top of the subsequent page(s)?
NisusUser wrote:For a multi-page table, is there a way to assign headers to a table so those headers will repeat at the top of the subsequent page(s)?
No.
(One might try using a table in the actual header (with only the column headers, but the same spacing. Might not look so great though.)
NisusUser
Post by NisusUser »
No.
OK. I'll just wait then until no more shifting of the text will occur and add rows at the top of the pages.
chabotd
Post by chabotd »
I was a heavy user of "repeating table header(s) on each page" in Word, I sorely miss it. I hope you consider this a "feature request", no a solved issue.
Sincerely,
Denis
greenmorpher
Post by greenmorpher »
I have a feeling this request goes back practically to the beginning of time. It just hasn't happened.
Cheers, geoff
DR King
Post by DR King »
I am a new fairly new NWP user, and I too would like to see table headers repeat themselves on each new page. I noticed this capability was requested several years ago. Has anything changed since then? Is there a NWP feature for propagating table headers? If so, can someone explain how to activate it?
Thanks
