NWP 3.0.4 How to assign menu key to Insert > Hyperlink > Remove Link
NisusUser
Post by NisusUser »
I'm wondering if there's a reason that I cannot assign a menu key to this.
The function Insert > Hyperlink > Remove Link works fine in v. 3.0.4, and I need to use it several times in several files.
But when I go to Preferences > Menu Keys, I cannot find any "Insert" item to dig down to the final command.
I have in the past assigned menu keys to other items under the "Insert" menu, so I know there must have been a way to do it.
Is this user error or a bug or something else?
Re: NWP 3.0.4 How to assign menu key to Insert > Hyperlink > Remove Link
Screen Shot 2020-01-19 at 24.54.28 .png (160.96 KiB) Viewed 7524 times
NisusUser
Post by NisusUser »
Hi, Philip! That's not what I see. Here's what I have:
Screen Shot 2020-01-18 at 17.58.17_sm.jpg (53.99 KiB) Viewed 7521 times
Screen Shot 2020-01-18 at 17.58.37.png (17.58 KiB) Viewed 7521 times
NisusUser
Post by NisusUser »
Ahhh! Now I found it! I just had to slide the bar at the bottom to get back to the main menu items. Sorry about being, well, not too alert :)
Screen Shot 2020-01-18 at 18.10.19_sm.jpg (48.37 KiB) Viewed 7521 times
